You guys are a bit harsh I think. In the video they make it clear this is to be used on the power lines feeding a residence, so as mentioned, that will be 240V in most places outside of the US. Even if it is 120V as it would be here, there are plenty of power supplies that can accept a wide voltage input, I have seen some that can accept 85-285VAC with no adjustments.
The problem is more in that video production, where someone got a little ambitious in saying it would be good for tapping into power lines in deserts and jungles "where there are no outlets"; that would be false. If it is designed (as the inventor said) to connect at a residential service drop, one would have to assume there is an outlet available in the residence, but maybe not accessible. Remember it was commissioned by Special Ops, so most likely the spooks don't want to knock on Mohamed's front door to ask him if they can plug in the battery charger for the smart bomb tracking system they put on his roof...
