Is this bonded correctly?
Mjohill92
New User
MA
Apprentice
Is this service disco bonded correctly? The disco is located after the meter and before the panel inside. Leaving the disco to the panel are the 2 legs and a neutral. I don’t see a ground. Is this correct? Shouldn’t there be a ground rod with a ground attaching to the disco and bonded to the neutral?
What code cycle was this installed under?
Could it be an emergency disconnect?
Where is the MBJ?
What type raceway from disconnect to panel?
Note that your last question is about grounding, not bonding, and should be detached from the rest.
