I've got a situation where there are two 2 1/2" rigid nipples sticking out of a concrete floor in the corner of a room. The nipples extend about 2" above the floor and are a pretty cockeyed. There used to be a 12 x 12 junction box that was loosely attached to these two conduits and sat about an inch off the floor. I'm replacing that box with an 18 x 18, and I'd like that box to sit on the floor rather than 1" above.
Looking at this, it would be pretty easy to cut the holes a little oversize and set the box down over the two pipes and get the results I want. I'd then use grounding bushings on the two pipes to bond them to the steel box. The oversized opening is closed (against the floor), fulfilling that requirment, and the conduits are bonded to the box. I've looked through the code and haven't found anything yet that would prohibit this -- am I missing anything here? Any violations I haven't thought of?
This isn't the kind of thing I like to do normally -- but I'm cleaning up someone else's mess and trying to do the best I can with what I've been given.
So, does this pass?
D.
So, does this pass?
D.
