Sorry I only followed the one line. My bad.
That's OK. I made a mistake once--thought I was wrong!
Here is the diagram for a simpler speed control.
Rattus, I appropriate what your showing in this thread, I do have a few questions though:
This last diagram (#22) is a simpler one line diagram, I had to get real close to see a little gray line extend across the two "contacts", four total on the main windings. I checked back to #1 thread and yes they are there, I had missed this earlier.
Until I saw the gray what I was going to ask is how a complete path was accessed /gained across what looked liked isolated terminal points! (?)
I don't understand how the reverse terminal points work, is it a N/O contact, or is the reverse switch physically rotating to the contact point?
Or does a reverse switch work as to were it touchs the Main coil and the coil is still harded wired across the terminals, based on this or the first question?
Does a speed switch work by having internal arms, locked in position, (like arms of a clock) that sweep into the position to the desired application?
Thanks in advance, Great thread BTW !
PS: I have a Great motor book, I'm not to lazy to open it. I just wanted to get those at home playing along to also THINK! :roll:
It actually works like a 4-way switch, which is a reversing switch. In the schematic, it's effectively turning the left-hand coil over, reversing the direction of the current through it.I don't understand how the reverse terminal points work, is it a N/O contact, or is the reverse switch physically rotating to the contact point?
Basically, yes. There's an insulated piece that rotates with the knob and carries a conductive strip as it spins. Open one up some time.Does a speed switch work by having internal arms, locked in position, (like arms of a clock) that sweep into the position to the desired application?
