- San Francisco Bay Area, CA, USA
- Electrical Engineer
I agree. There is no rule against it, other than common sense. Disconnects and breakers built to NEMA standards are required to handle starting duty of motors. The thing is, the test durability requirements are not as tough for them as it is for contactors. Knife switches like what is shown must, per NEMA KS-1 standard, be able to switch at their RATED motor load at least 1,200 times (UL requires only 1,000 operations). But although the NEMA standards for contactors don't specify a number of operations, the general design is for 1 million electrical operations under rated load, 10 million mechanical. Bottom line, switching something on and off using the disconnect is not a great idea because you will severely decrease their service life and they are not simple to replace (in an MCC bucket), but is not something expressly forbidden.I don't think it is dangerous so much as it may result in some minor reduction in equipment life the big problem imo is the time wasted in doing this kind of thing and what loss of production results.
A better way to temporarily get around interlocking issues (which are there for a REASON by the way) would be to add a "Jog" momentary push button that just ignores all other control paths and goes straight to the contactor coil.
