Jerseydaze
Am I correct that a railing at the top of a loft counts as wall space and I need floor recepts in a residence
yes it counts as wall space.Jerseydaze said:Am I correct that a railing at the top of a loft counts as wall space and I need floor recepts in a residence
the rail doesn't need one but the floor along the rail does assuming it's a long enough rail.Dennis Alwon said:I believe it was Charlie B that thought not but I believe the rail at the loft needs a receptacle.
steelersman said:the rail doesn't need one but the floor along the rail does assuming it's a long enough rail.
That seems like a lot of unnecessary work to do all that.Dennis Alwon said:No, I believe you absolutely must cut the rail out and install a pop in box in the rail. Art.1435.19 (A). :smile:
steelersman said:That seems like a lot of unnecessary work to do all that.
good idea. finally someone agrees with me!celtic said:I agree...why can't we use a mineralac/cowboy and a bellbox and skip the sawing?
steelersman said:good idea. finally someone agrees with me!
ok I guess.frizbeedog said:Will you stop smiling now?
Did I say that? Huh? Well, if I did, then I was right. So there!Dennis Alwon said:I believe it was Charlie B that thought not. . . .
See the comment above about my being right.Dennis Alwon said:. . . but I believe the rail at the loft needs a receptacle.
charlie b said:Yes. And your point is? :-?
So perhaps it might be a good idea to put a floor-mounted receptacle by a railing. But the present wording of the NEC does not require them. Reference: Charlie's Rule. :wink:roger3829 said:That would make it a room divider. Someone could put a table with a lamps in front of it
Now that I have taken another sip of my coffee, I am beginning to recall having a discussion (debate?) of this topic. I believe I had said that a railing at the top of a staircase does not divide a room from another room, but rather divides a room from probable death (i.e., from falling over the precipice that would be created by the absence of a railing). If you were to look at an architectural plan (I do this a lot, in my job) of the second floor of the house, you would not see a "room" on both sides of the railing. Thus, it is not a "room divider."
More to the point, I believe a railing never requires a receptacle, because it is never considered wall space! Now before you all jump on me with 210.52(A)(2)(3), let me ask if anyone, anyone anywhere, has an English language dictionary that defines the word "afford" in any context that matches the use of that word (or the word, "afforded") in the manner used by that NEC article? Mine does not. The closest it comes is the definition, "to furnish or supply," and that does not do the job.
OK, let's get this one put to bed. I hereby pledge that by the end of the day tomorrow (Friday, 10/3), I will have submitted a proposed NEC revision that recommends eliminating the word "afforded," and that clarifies the intented meaning of "wall space." It should have a good chance of approval, since every single proposal I have ever submitted has been approved! Anyone else out there batting 1000 with a 4000 slugging percentage? :grin:
