No.If your using a wiggie as your only source to check for voltage under load and it shows NO, are you safe from electric shock hazard ?
and I don't trust digitals alone either. I verify with another meter, neon tester, etc. and usually ground the conductor as the last test (well, next-to-last as the high-impedance hand or finger brush is last).No there are some instances were there is insufficient current to make the wiggies solenoid to move.
Is that "NO" as in no voltage present/detected?
Or is it "NO" as in "normally open"?
Why are you asking, do you have reason to believe your meter is not accurate?
No as in plunger didn't activate and meter didn't vibrate. The NO or GO wiggie reading
Could this insufficient current hurt or kill someone ? Should I not use my wiggie anymore?
