Isn't this awesome
More accessible but lacks GFI.
Also needs an in use WP cover:D
I never understood the need for receptacles in commercial bathrooms.
There are some where it may be likely for personal use at times, this typically not going to be in retail stores, public event venues and similar. Then there may be need for one (not necessarily near sink) for a vacuum, floor buffer, etc.
I'd agree they are underutilized the majority of the time. However, I typically try to have at least (1) outlet in every room, even storage closets and what not. Never know when an owner will want to plug in a dehumidifier, need power for a plug-and-cord tool, portable space heater, etc. Probably excessive, but this is the golden age of CYA.
And where do you stop? Better put in a couple 50 amp welder receptacles and a 200 amp 277/480 volt pin and sleeve style receptacle as well, just in case.
Just like everything else, you stop where the likelihood of such a thing being needed falls below the pain of installing it.
...Incidentally, another gotcha for that installation from the ADA:
"...nothing can be installed directly behind the grab bar"
Not a very good rule. For example, does that include new tile? wallpaper? One could argue that a flush-mounted receptacle wouldn't count, too, even though it's probably 1/4". Just don't plug anything in.
Look at it from a time perspective, and it wouldn't include anything existing before the grab bar was installed, too.
Does that rule only apply when a grab bar is required by its law? Or does it apply to every optional grab bar out there?
Great planning... I hate it when I get to a job and they changed the door swing and never told us about it.
That's funny Dennis. I worked on a job about 15 years ago where the homeowner/general contractor changed the swing on a half dozen doors. No one noticed until the walkthrough. The doors were installed after we had trimmed out the house. No corrections were made that I know of. We wired to the onsite blueprints which had failed to get corrected.
