- Tennessee NEC:2017
- Semi-Retired Electrician
I know little about the "voo-doo" of these type circuits, but enough to know that I don't believe they accomplish anything. With that said, I've been asked to bid on a job that calls for some isolated ground receptacles.
My question is can more than one isolated ground be on the same circuit?
If so, how do you run from one receptacle to the rest?
If some receptacles are in a separate room (same building) can you jump over to the other room to pick up those receptacles?
Is it common when using cable (MC or NM) to re-identify one of the ungrounded conductors for the isolated ground?
