NorthwestPV
- Oregon, US
A lot of our jobs call for isolated ground receptacles (not patient care). The issue I have is on the isolated ground receptacles we are using, the yoke has continuity to the receptacle ground. If you ground the box with the equipment ground, it makes the entire isolated grounding system no longer isolated. The circuiting is almost always in EMT. If the receptacle was recessed, I could see using a plastic mudring. What do you do if it is installed in an industrial cover? I have seen hospital grade receptacles with two separate grounds but my employer does not want to pay the cost difference for these. I was wondering if one could use a PVC fitting in the conduit run to isolate the grounding an that circuit? Is there another option?
