Re: Isolated Ground
I realize that more than one Isolated Ground receptacle can be on one circuit. I was referring to using standard receptacles on one circuit and calling that the same as "specified" Isolated Ground recep.
I feel that if Isolated Ground receps are spectified, then use the recep's with the orange triangle and install per instructions.
I am not not commenting on that the circuit "will work".
If I order a Cadillac, I do not expect a Chevy.
I am sorta thinking of the swimming pool motors being 2.5 HP installed on a circulating pump that only requires a .75 HP motor to drive the pumps at the rated capacities.
At the rated 1750 RPM ( or if rated for 3450 RPM ) that pump will deliver the rated output with either HP motor.
Paying for a Caddy when a Chevy will do just as well, but the Caddy was specified by the owner.
I don't care if it is a " Home Theater"
P.S.
If I were the owner, I would want what is specified as long as it meets the "CODE".
As an inspector, I can only check that it meets the minimum code.
Many owners do not get what they paid for if they don't have their own inspector, which should be the design engineer, which went over the plans with the owner before installation.
[ May 15, 2003, 07:17 AM: Message edited by: gwz2 ]
