gar
- Ann Arbor, Michigan
- EE
080628-2059 EST
Bob:
Because you follow code does not necessarily make something safe, not following code does not necessarily make something unsafe. The code does a lot of good, but in some areas it also may be further dumbing down the US population and making them less responsible for their actions because they are supposed to be protected from everything by someone else.
Personally I see no need for sliding protective covers over the slots in an outlet. These may become a real reliability problem. Children need to be taught to not put something in one of those slots.
Was or is aluminum branch wiring safe because it was allowed?
Are outlets with poor spring fatigue life safe? Somehow they got UL listing. I encounter these in motels where the plug falls right out.
Are outlets with spring contact termination safe compared to a screw clamp?
If you put excessive rules on business they will be ignored, go out of business, or go somewhere else like China or India.
I am not trying to negate the good of the NEC code.
Still the the original question problem is what problem needs to be solved.
Bob:
