- Licensed Electrician
People bring in motors all the time saying, "It just quit running." The first time ever finding this to be the problem. This came off a hydraulic pump at the local concrete block co.
It was dropped off at the shop so I'm not sure. No cover on the peckerhead is my guess.With that extra "i" in the title it looked like it said "it just quit ruining"!
I'd say that about summed it up though!:lol:
How'd all that concrete get in there?
That I have seen. Grease surpasses WD - 40 for maintenance guys and farmers for motors.We've got a motor shop and that type of stuff never stops being hilarious to me. I think my favorite was the one where the "maintenance" guys pumped so much grease into it that they filled the gap between the rotor and stator. I may have pictures of that somewhere.
We were able to bring it back to life. Took longer to get it cleaned out than it did to change the bearings.Junk motors, there is no reason that should not keep running.
It would be cement, not concrete. Concrete has sand and gravel... But I know what you meant.... How'd all that concrete get in there?
Exactly the problem I've run into trying to do switchgear maintenance at cement plants: Adding lubrication to anything will accomplish the exact opposite of what your were hoping to achieve....the Portland cement dust, then via condensation when the motor is turned off, it gets a little moisture, so some of it solidifies....
Indeed.That's why they make TEFC motors.....
Indeed.
Had it been, the resulting influx should not have been possible.
I like your dry sense of humour...........Not only that, the cement would have stayed out of it too.
Who do you think meant that and why?:blink:TEFC still has a fan; Totally Enclosed Fan Cooled. I think you meant TENV,
This one did get dipped and baked but only after a trip to the car wash and then some detailing with a nylon brush, an old screw driver, and what was basically a popsicle stick to dig out the crud, along with repeated blasts with the air hose.Hey Dave, after you get that gunk out, then what?
Assuming that no rewiring is involved...
Do you dip it, do you use any chemicals at all? Is it just vacuumed and that's it?
Got me confused as well, TEFC has a fan but is still totally enclosed so nothing gets inside.:blink:TEFC still has a fan; Totally Enclosed Fan Cooled. I think you meant TENV, Totally Enclosed Non Ventilated. They are a lot more expensive and only available up to certain sizes. In the case of Baldor, it stops at 1-1/2 HP.
