Fulthrotl
~Autocorrect is My Worst Enema.~
- E
You nailed it with the sporatic use - they usually do not run long enough to get too hot, except for fans - but those often are located in the air stream anyway.Not sure why they put fans on ag motors. A good share of them have the fan cover gone and or the blades. They last for years when used sporadically in grain handling. Amazed at how much abuse motors can take.
This one did get dipped and baked but only after a trip to the car wash and then some detailing with a nylon brush, an old screw driver, and what was basically a popsicle stick to dig out the crud, along with repeated blasts with the air hose.
In general 10HP or less are not worth rewinding, I guess this one wasn't rewound but still had a little intensive care put into it. Only time a 10HP or less is worth it is if it is not a standard NEMA motor, or depending on how desperately it is needed sometimes you can have one rewound in less time then it takes to get a replacement for something not in stock.Based on the size of the sledge hammer in one of the photos, this doesn't look to be a very large motor. Was it really cost effective to run it through intensive care? I would have thought that replacement might have been the cheaper course of action, but I admit it's been a really long time since I bought a motor for anything.
It's a 40hp c face motor and yes it was cheaper to work on this one instead of buying new.Based on the size of the sledge hammer in one of the photos, this doesn't look to be a very large motor. Was it really cost effective to run it through intensive care? I would have thought that replacement might have been the cheaper course of action, but I admit it's been a really long time since I bought a motor for anything.
small motors to some are not as small as they are to others. A big motor for me is anything over 25 HP, but for some anything under 100Hp is considered a small motor.:happyyes:
