goldstar
- New Jersey
- Electrical Contractor
After seeing Dennis Alwon's post about hot tub bonding I was reminded of an installation of a Jacuzzi tub that I recently wired. In past installations many EI's informed me that I not only had to install a (green) insulated # 8 solid from the lug on the motor to a cold water main but that water pipe clamp had to be accessible for servicing. As such I have always run the ground wire to a point where the clamp could be replaced if it corroded. In all cases that I've seen the water is fed to the tub on one end and the motor is on the opposite end. Can I legitimately install the ground clamp on pipes at the front end of the tub or do I have to run it to a point where it is accessible ?
