Jamb switch
normbac
Plans show door jamb switch. Jamb is commercial door metal jamb. my concern with using high or low volt switch is that it will protrud and cause door closing issues. With wood jamb it can be chiseled flush but not sure how to apply to metal jamb. Anyone ever had this issue? TIA
Use captive nuts on the switch plate and slide it inside the jamb channel to be held with flat head screws in countersunk holes?
Tapatalk!
If they order the door frames correctly there will be a spot for it.
That said I would push for a motion sensor instead.
