This doesn't answer the OP's question, (which got done nicely allready) but I usually run the jetted tub circuit over to the bathroom and take it first to a gfi receptacle outlet on the other side of the bathroom someplace (but not the countertop one) and then load side feed a receptacle under the skirt. Now I see this is going to become a requirement for us when we get to 08, or else use the gfi breaker. Good. This is one change I don't have to do any learnin... Side note: lately I have been running into an awful lot of tubs that require 2 separate 120 volt 20 amp gfi protected outlets, one for motor, and one for heater. Or a new variation which is one circuit for each of two motors that are on opposite ends of the tub, which means two access panels to deal with. And of course the old suprise suprise- 240 volt motor which means I got to go buy an expensive gfi 2 pole breaker now that I didn't plan for in the bid, since it just showed a jetted tub on the plans.
