360Youth
- Newport, NC
We went to a job to day where the customer has an existing generator and 200 amp ATS on his home with a 400 amp service, with the ATS and genset taking on one of the two panels. He wanted to know if it could be set up that both house panels would be served by the generator and ATS. First answer was a 400 amp ATS, but equipment alone was $2500+. Next answer was to redesign what he had to be fed by the single switch, which is what we ended up doing. The first necessary item was a disconnect that was never installed ahead of the ATS by the original EC. Having that 200 amp disconnecting means enabled me to feed both panels from the ATS. I am always curious and encourage comments from people that like or don't like a particular design and anxious to hear how it could be different or better. This one was a first for me and came out ok considering some of it design on the fly because all we had was customer photos to go by. Go easy on me (), but tell me what you think. Inspection will probably be next week because inspectors are taking CE courses most of this week.
BTW, the amp readings show the entire house load after everything was turned back on. I guess the original 400 amp service was a little overkill. :grin:
Service Change
Service Change
