I need some more information - cause an answer of: "Use a coupling and the right glue" seems a bit simplistic.EEC said:Any methods you can think of too couple 2 pieces of 4 inch PVC conduit and doing it by yourself?
Am I the only one who thinks the grey glue sucks? I always look for the extra-strength (green label, I think) clear solvent in the plumbing section.JohnConnolly said:Get two strap wrenchs and lots of gray glue.
LarryFine said:Am I the only one who thinks the grey glue sucks? I always look for the extra-strength (green label, I think) clear solvent in the plumbing section.
JohnConnolly said:The grey glue is slower setting and I can see where it's been applied.
If your glue is not "sticking" it's because of undersized pipe or oversized fittings. PVC glue doesn't work via adhesive, it just closes the very slight gap between the pipe and fittings. That's why it it easy to chip out broken or mis cut pipe from fittings.
If the specs are off a tiny bit, it won't "stick".
As mentioned already a short piece of 2x4 and a hammer is probably the quickest and easiest way, at least for me.EEC said:Any methods you can think of too couple 2 pieces of 4 inch PVC conduit and doing it by yourself?
