M4gery
I have a fix too when the plumbers and masons go to lunch make nice little balls of mortor and slide in the pipes they have left open
Sabotaging the customer's home is disgraceful and illegal.
I have a fix for that, if you're interested.
This too often happens in custom/high end residential... Of course after an RFI to GC and 'Design Team' to hack out a cost vs. intent result... For that matter if it was new framing - it was on the GC to frame to accomadate the light...If I had prints that showed the light in the center of a counter the carpenters would be sistering two joists and heading off the one in the way.
This happens often in commercial work.
I have a joist on 24'' center from wall down counter top , I have to put the 6'' cans on either 28 3/4 '' or 19 1/4 '' center from wall , which is best ?
19" on center would be about 151/2" to the edge ,.with sheet rock ,..top cabinets with crown molding, if used ,.. would be mighty close
I don't understand the problem, cut the joist and box it out. Do it all the time.
Yeah, got to watch that beefy crown molding.
Maybe I am misunderstanding but, what carries the weight of the cut joist?
The joists on either side.
That is a building code violation unless you sister joists on either side and head off the cut joists.
Are you sure it's a violation in all situations? I thought it depends on the span, joist size, etc?
When we talk about joists in residential construction, I assume we're talking about I-joists.
When I see the word "Joist" I think 2X8" or 2X10", etc. What you are talking about is usually referred to as a TJI or I-joist.When we talk about joists in residential construction, I assume we're talking about I-joists.
Heading off the cut joists into the adjacent (trimmer) joists is of course a requirement for any opening. But for conventional light frame construction using dimensional lumber, you only need to double the trimmer (and header) joists when the header is over 4 feet in span. [2006 UBC 2308.8.3]. Of course doubling may still be a good idea, since conventional framing practice is sometimes bouncier than desirable.That is a building code violation unless you sister joists on either side and head off the cut joists.
