 - Chapel Hill, NC
 - Retired Electrical Contractor
What convention are you using to relate the Phase letter to the wire designator?
I will call the wires L1, L2 and L3 to avoid any other association. And I will call the voltage from L1 to L2 Phase A, the voltage from L2 to L3 Phase B and the voltage from L3 to L1 Phase C.
So when you say a load is connected to A and B only, that means that one load is connected between L1 and L2, the other is connected from L2 to L3. So the current in L1 is 49kW divided by the Phase A voltage. The current in L3 is also 49kW/V. The current in L2, however, is the vector sum of the two currents from the two loads. That one will have a sqrt(3) factor in it, and will not be in phase with either load voltage.
Okay then why did gar say if I connect 2 loads to line one and line 2 only the resulting reading on one line would be additive of the 2 lines. At least that is how I read his comment. Is that because we are not using L1, L2 and L3?
