mrmartyok said:.... my question is do I have to have these exposed and cover with a blank plate or can I bury them in the ceiling?
ptonsparky said:You don't want to know how many holes I have punched in finished nicely painted sheetrock, to find J boxes that have been covered. I don't like making the holes and the owners don't like the ugly blue cover right next to Aunt Martha's portrait.
i would tell the owners to move aunt marthas portrait over so they dont see the ugly blue cover :grin:ptonsparky said:You don't want to know how many holes I have punched in finished nicely painted sheetrock, to find J boxes that have been covered. I don't like making the holes and the owners don't like the ugly blue cover right next to Aunt Martha's portrait.
LarryFine said:He could always use a plastic architectural access panel beneath each box.
Along the lines of this topic, I have heard that there is a heat shrink splice that you can use that can be burried in a wall space and will still be code compliant. Is this correct, or someone is trying to take the easy route? e/mLarryFine said:He could always use a plastic architectural access panel beneath each box.
Energy-Miser said:Along the lines of this topic, I have heard that there is a heat shrink splice that you can use that can be burried in a wall space and will still be code compliant. Is this correct, or someone is trying to take the easy route? e/m
Energy-Miser said:Along the lines of this topic, I have heard that there is a heat shrink splice that you can use that can be buried in a wall space and will still be code compliant. Is this correct, or someone is trying to take the easy route? e/m
Thanks, that helps. e/miwire said:Check out 300.15(H) and particularly 334.40(B)
