Strahan
- Watsontown, PA
quogueelectric said:Buy yourself a little cube tester and run around and see what it tells you. They are very usefull tools in troubleshooting. this is probably what the home inspector will also use.
When you say cube tester you mean the plug in recept tester right? If so that is what he used to determine I had a Loose ground. Once I started searching I came to the conclusion it is in the ceiling somewhere. With selling the house so soon I'm thinking of putting the gfci breaker in.
