Phase has been defined as the argument of the sinusoid describing the wave, i.e.,
phi = (wt + phi0), an angle.
I see no problem with using it to describe voltages with different phase constants. The practice is forever burned into our minds.
The problem isn't using the world phase for field practice (2). The problem is whether you plan to answer the OP question which requires definition (1). The definitions are incompatible.Phase has been defined as the argument of the sinusoid describing the wave, i.e.,
iwire -
I had understood the 2500+ post, dumptruck load was to be reopened. Is this it? From gar's opening post, I didn't think it was.
ice
As I said in my post when I closed that thread, I planed to reopen in 24 hours unless the other mods had other opinions. Right now it is still up in the air.
For us to put it back would mean one of us would have to edit out the comments. I can tell you that is not an easy task as the jabs and insults are usually interwoven with legitimate comments and no matter how the edits are done everyone will be upset.
The primary coil imparts an EMF that drives the current in the secondary. The voltage in the secondary is created by the current passing through the inductive coils as:
A -----------+-----------> B (240V<0)
We tap at the center to get:
A -----------> N (120<0)
N -----------> B (120<0)
For resolving to the OP question we must use definition (1) which requires that the two legs are measured in a common direction defined by the system.
In the field we reverse our leads using (2) to
B <----------- N (120<180)
to get opposing voltage phases for each leg.
A property that's certainly valuable for the majority of field applications such as full wave rectifiers
But again by definition (1) when we reversed our leads we should have inverted the polarity of the graphic to either:
B -----------> N (120<180)
or
B <----------- N (-120<180) == (120<0)
Again resolving back to the original "in phase" for both legs. No phase angle is being discarded.
This is supported by the basic circuit concepts:
The resistance/inductance of AN == BN since this is how we build a secondary coil (sorry about the obviousness).
The secondary is not actually a supply but an induced coil or load where each leg is E=I*(Rcos+Lsin).
(Rcos+Lsin) does not have direction. The direction of I is imposed by the primary coil and is therefore traveling from A to B or from B to A at any given instant.
I have old references that use "vector" and some that use "rotating vectors". As we know, the term phasors was used to distinguish from vectors and the use of "vectors" fell out of favor because of the confusion with space vectors. I would be interested if you find the origin but Steinmetz would be a good guess as, from what I understand, he is the foundational source for most of our AC math and circuit analysis....One book reference I found on Google seems to imply that Steinmetz described his concept as a rotating line (probably meaning some form of vector). This means it is really necessary to look at the original 1893 publication.
The simple fact is that if
V1n = 120Vrms @ 0
then,
V2n = 120Vrms @ PI
Nothing can be done with the phasor diagram to change this fact. It is true even without a phasor diagram.
They are inverses. Inverses are PI radians apart! Nuf sed!
BTW, swapping leads does NOT change the phase of a waveform. There is no reason to talk about leads when discussing phasors. The phases are what they are and cannot be changed by anything one does with leads or on paper.
Furthermore, the expression Rcos + Lsin make no sense at all. There are no arguments for the sine and cosine? And it is dimensionally inaccurate.
I think the OP's question has been answered satisfactorily. Most people seemed to understand it.
Hehre and Harness copyright 1942 does not mention phasor. The entire discussion uses the word vector, and one chapter is on Complex and Symbolic Notation. Most of their vector diagrams are from a single point, even for a delta circuit.
You're not following because you're stuck on definition 2, which is shown in the middle graphic of post #22.I will just say that Van and Vbn are properly defined as,
Van = 120Vrms@0
Vbn = 120Vrms@PI
The phase constants are 0 and PI,
I can't follow the rest of your argument.
Somehow I get the right answer even by doing it wrong.
BTW, you reversed the graphic TWICE to arrive at an impossible result.
Correct by definition (2) only.The simple fact is that if
V1n = 120Vrms @ 0
then,
V2n = 120Vrms @ PI
By def (2) swapping leads does not change the waveform. By def (1) it does. Since (2) doesn't answer the OP question about why it's called single-phase we have to discuss def (1) so leads do have meaning.BTW, swapping leads does NOT change the phase of a waveform. There is no reason to talk about leads when discussing phasors. The phases are what they are and cannot be changed by anything one does with leads or on paper.
You are completely wrong.
Pray tell me how?
Yes, by the end of the post the graphic has been reversed twice.
No, it's not impossible by definition (1) which is where the second reversal takes place, but yes, it's impossible if you can't get off definition (2).
As to "no arguments for the sine and cosine" I work a lot with mathematicians who use shorthand. Express the arguments as you like as long as they're identical.
For one of the voltages, pick the other point as a reference. then they are both in phase.
Yes, but the reference is stated to be the neutral, and the voltages are Van and Vbn. So I am completely right.
Two hots and one neutral makes a case for the neutral being a common sense choice as a reference.Who says the reference has to be the neutral??
As far as I know, there is no official definition for the term 'phase' as used to describe the lines of a multiphase system.
