tx2step
- North Texas, DFW area
Re: K&T sign off??
For a test load, how about building your own "Load Bank" using 150 watt lamps?
At 120V, each lamp will pull 1.25A. You could fine tune the load for voltage variances by using an ampmeter and a few smaller wattage lamps.
It might not be pretty, but it would be cheap and effective, and you could easily vary the load to whatever you want it to be.
Or you could start with a 1500W fixture (12.5A at 120V) and add a few more 150W lamps for additional loading up to 15A or 20A as desired.
Incan. lamps are just resistive loads - the same type of load that is used for generator load bank testing, just on a much smaller scale in this case.
