PetrosA
- Lancaster, Pennsylvania
That panel seems to suffer from serious corrosion, judging by the rust marks on the breaker faces, the rust on the breaker rivets, and both the bottom of the panel inside and outside. Whew.
HOW would have the clamp prevented that?
I know... but the section I quoted states enclosures, too. A kenny clamp is for GEC metallic enclosure entries and exits... though the latter is atypical of most installations.The kenny clamp is not for use with raceways.
Roger
. UL 67 list bonding screws for residential panelboard at 30 amperes. Don't rely on the bond screw for ground-fault continuity.
The last sentence there is what I question, NEC wants us to rely on the bond screw, otherwise it would require use of other methods![]()
Not for the GEC connection to the grounded conductor. As I [vaguely?] pointed out earlier, you cannot land a GEC on an equipment grounding bus (EGB) connected to the enclosure solely by screw and the a bond screw is used as the MBJ/SBJ. There has to be a wire-type MBJ/SBJ sized to Table 250.66 between Grounded conductor/bus and EGB in order to land a GEC on the EGB.... Don't rely on the bond screw for ground-fault continuity.
Asked today, about 9 dollars. (didn't get it).
Yikes! A product looking for a purpose.
That panel looks like it was flood damage, is this left over hurricane damage? is it in a basement?
If it was sure hope you getting paid is not dependent upon the insurance paying:happysad:
