I would break that promise a lot myself :smile:charlie b said:I don't promise to do it the same way every time.
mivey said:Just to be picky, while we are getting the notations straight (I have to keep reminding myself of these): the associated abbreviations are kWh, kW, kvar, kVA, kA, kV, kJ, hp, Ah, Hz, Btu, ac, dc, rms, h
Basically because IEEE publication guide says so. For most units there is a logic. The names of units and prefixes always begin with lower-case letters except at the beginning of a sentence (except for the degree Celcius for some reason unknown to me). The symbols of units begin with a small letter, except where the symbol is derived from the name of a person (N for newton, g for gram). The symbols of all prefixes are small letters, except for prefixes dealing with multiplication factors of 1,000,000 or more. I guess the logic is that var is a name of a unit, not a symbol, whereas VA is a symbol for the unit voltampere.weressl said:but MWh
why kvar and not kVAr or kVAR
and I think AC and DC
jghrist said:Basically because IEEE publication guide says so. For most units there is a logic. The names of units and prefixes always begin with lower-case letters except at the beginning of a sentence (except for the degree Celcius for some reason unknown to me). The symbols of units begin with a small letter, except where the symbol is derived from the name of a person (N for newton, g for gram). The symbols of all prefixes are small letters, except for prefixes dealing with multiplication factors of 1,000,000 or more. I guess the logic is that var is a name of a unit, not a symbol, whereas VA is a symbol for the unit voltampere.
Unless you are talking about MMBtuweressl said:M for Mega and m for mili for example.
charlie b said:Thanks, Mivey. But I will continue to abbreviate these terms as I wish, and I don't promise to do it the same way every time.:smile:
mivey said:Unless you are talking about MMBtu
[edit: also see http://www.ieee.org/portal/cms_docs/pubs/transactions/auinfo03.pdf]
Are you trying to moderate the moderator? Is that even allowed? :grin:Jraef said:But look at your first response carefully. You put "KHW", not KWH and you did it twice! Surely you don't espouse changing the order of the words as well!
(and I'll call you Shirley if I want to!) :wink: :grin:
drbond24 said:That link is working about like I do on a Friday afternoon.
(It isn't working, in case the implication wasn't clear. :grin: )
mivey said:I think I fixed my typo now. It should have been:
Shucks. Now I am going to have to admit this error at my next meeting of the EDA (Engineers Against Dyslexia).Jraef said:But look at your first response carefully. You put "KHW", not KWH and you did it twice!
