- San Francisco Bay Area, CA, USA
- Electrical Engineer
...or as they (we) would abbreviate it, DAE :roll:charlie b said:
Shucks. Now I am going to have to admit this error at my next meeting of the EDA (Engineers Against Dyslexia).![]()
Jraef said:...or as they (we) would abbreviate it, DAE :roll:
"e" eht ffo tfel uoy kniht I tub eb thgim eHweressl said:Are you a Dadaist?
The kilowatt-hour (kWh) is a unit of energy not power. The kilowatt is a unit of power. The joule is a unit of energy.Texass said:kilowatt-hour (kWh) is a unit of Power. 1 kilowatt-hour means that it will use (or transfer) one kilowatt every hour. One kilowatt is the power of one thousand joules (J) per second (s). the h in kWh basically signifies just the alternative time unit used.
If you really want to know what the conversion for kWh to kW...
1 kWh = 0.000277777...kW
1 kW = 3600 kWh
1 kW = 1 kW consistent for 1 hour, or 1 kWh
1 kW = 1000 J / s = 1 kJ / s
1 kWh = 1000 J / h = 3.6 kJ / h
jghrist corrected the errors in your post but you must have had something in mind that you were trying to express. I'm just curious, but I'm guessing you might have been trying to reference an hourly demand interval?Texass said:...the h in kWh basically signifies just the alternative time unit used...
kWh alone will not give you the answer you need. At best you can get an average demand. You will need some kind of demand reading or you will have to conduct a load count.Texass said:yes, i'm an electrical E.I.T.
i was asked to see if the existing panelboard in a renovation project had the capacity to add on more circuits, and the only information i have is the monthly kwh for the past year. I wanted to calculate the peak and see if I added more amps to it, would the panelboard be able to support this. i don't think i can get a true answer, but any help would be appreciated.
thanks.
