Kitchen receptacle over range
jmb123
New member
In an existing dwelling above the kitchen range is a 120 volt 15 amp receptacle. Was this a violation of the code 40 years ago. Is it a violation of the 2002 NEC.
Re: Kitchen receptacle over range
It is not a violation to install a receptacle outlet on the wall space above a range. It would probably not be the best design however. It is also not a violation to install a receptacle directly behind a sink either.
I can't imagine this was an issue 40 years ago. :)
Many years ago electric clocks were 120V. I have installed recessed receptacles for kitchen wall clocks. You can always blank the receptacle off.
