2005 NEC, looking through previous post and the code, I cant seem to find if this install is correct. All kitchen counter receptacles are being fed from two 20 amp circuits directly from the service panel. The single receptacle for the island receptacle is being fed from the load side of a 20 amp GFI receptacle located in the basement which has no other outlets and is being fed directly from the service panel. My question is, Does this island receptacle have to fed from one of the two required 20 amp circuits that are required under 210.52 (B)(1)?
