Kitchen receptacles considered as wet location
Miami, FL
I am in the South Florida area and hadn't fail an inspection on this yet, but I hear from two inspectors that receptacles within 30 inches of sink are considered to be on "wet location", therefore need to be of the weather resistance type, none of them had provided me how they got to define it that way. The closet I can find on that as a wet location is a definition from UL Standard 1598, "a location in which water or other liquid can drip, splash, or flow on or against electrical equipment", this does not mention distance. It may be from Florida Building Code, but can't find it.
Wow, in all my years on this forum, first time I have heard of that issue. Are they asking for a WR receptacle? Here is the definition. If the kitchen was subject to saturation the counter and cabinets would not last long. Its an incorrect call.
I am in the South Florida area ..I hear from two inspectors that receptacles within 30 inches of sink are considered to be on "wet location"
EXTRA EXTRA READ ALL ABOUT IT
Without levy's blocking storm surge, inspectors worried about job security are enforcing wet locations everywhere.
South Florida planning departments are keeping the lights on under water, perhaps hoping to collect property taxes long after sea level rises over the rooftops.
Simple answer is that it is not by any stretch of the imagine a wet location by the NEC definition in Article 100. That means that there is either a local amendment or the inspector is making their own code.
Just playing devil's advocate here, but what if the sink faucet is one of those hose types that could theoretically be pulled out and sprayed right into the receptacle?
Still doesn't meet the Article 100 definition of a wet location.
Location, Wet. Installations underground or in concrete slabs or masonry in direct contact with the earth; in locations subject to saturation with water or other liquids, such as vehicle washing areas; and in unprotected locations exposed to weather.
What if a frog had wings? 😀
I can't tell you how many debates I've had in my office when another inspector asked "what if"
It is sad. Those inspectors should be politely shown how they are wrong. If they persist then they should be shown the door. Look at the definition in art.100 of location, wet
Then every receptacle should be a WR with in-use cover because someone can drag a garden hose in through the front door.
Apparently you haven't seen the photo of the dog that brought the sprinkler inside the house through the dog door :)
Does this same inspector require under cabinet lights near a sink to be rated for wet locations?
