kitchen remodel; derating
dan356
New member
First- this is a great resource. I have learned a lot from reading this today. Thanks to all of the experts who answer questions.
I am installing three new dedicated circuits in my kitchen, one each for range, vent hood and microwave. The range requires a 30 amp 240 V circuit. I'll install 6/3 NM cable for this, with a 30 amp breaker (being sure to cut the ground strap between the unit and the terminal block on the range). The vent hood and microwave each require 15 amp 120 V circuits. I'll use 12/2 NM cable for these. I plan to run all three cables (one 6/3 NM and two 12/2 NM) along the ceiling of the garage inside conduit, back to the circuit breaker panel.
My questions are: Considering derating, can I run all three cables inside the same 3/4" EMT conduit? Max ambient temp is 110 C. Could I instead use PVC conduit? Is THHN/THWN used inside conduit, instead of NM, just because it is easier to pull?
Thanks,
Daniel
Sorry, Dan, but we're not allowed by the owner of this site to answer DIY questions, as much as we like to.
