Fascinating!Originally posted by dlhoule:
I was involved in wiring of house in knob & tube in about that time
I have seen grounded knob and tube. I do believe it was a "homeowner" refit. Whoever did it fished a #10 thhn ground to each of the electrical openings and back to the panel. You know, open joints in the attic, etc. I suppose this arrangement would at least provide minimal protection so long as nothing got cut or broken, but seems to me it would have been easier and safer to just rewire in romex.Originally posted by al hildenbrand:
Do you recall if the receptacles were grounded? or was it all true to two-wire ungrounded?
If the receptacles were grounded, do you recall how that was done?
I wonder how many romex fires were started with wiring that was NOT overloaded?Originally posted by dlhoule:
Gentleman having it built was familiar with code and swore by knob & tube. He said he had never heard of a fire caused by knob & tube wiring, other than when being extremely overloaded.
You can't apply that section to that problem. They perform different functions, they're called different things, it doesn't work.Originally posted by Matt Harp:
I havent researched it, but I am of the opinion that 250.64(B) would be a reasonable application even though it is regarding the grounding electrode conductor.
