Cavie
- SW Florida
I personally walk away from N and T unless I replace all of it. It's a liability thing with me. All or nothing.
Your perspective provides more work for me (he says, pretending we live and work in the same jurisdictionI personally walk away from N and T unless I replace all of it. It's a liability thing with me. All or nothing.
Your perspective provides more work for me (he says, pretending we live and work in the same jurisdiction).
Here, in the old housing stock of inner city Minneapolis / St. Paul I would estimate that fully 70% of dwellings have existing K&T core wiring from original electrification that is still in service and will likely continue to be in service for another century at least.Fortunately we don't have much of it here in Florida. Lot's of work without having to mess with it.![]()
Right or wrong, there is a lot of NM (older cloth covered NM) extensions off the K&T around here, and nearly all are tapped onto the K&T in the open, so it must have been a standard practice even if code said otherwise.I do not read it quite that way:
Where the only wiring method is K&T, splices can be in the open. This was done during the original installation.
But in most of the pictures, the K&T is spliced to a different wiring method.
I do not see A-L applying to any of the splices pictured.
When conductors did leave knobs and tubes they were typically sleeved in a non metallic tubing - maybe in places where they were fished, or even just short lengths to a switch or outlet box.
And there was a lot of exposed live parts in some of that vintage equipment.
Open splices, usually soldered and then taped, were the preferred method of connecting K&T wire runs. Sometimes with a knob close for support, sometimes not. But what you have in the first picture appears to be a later tap of the K&T using the predecessor of NM. That connection should probably be made in a bo
The shiny boxes, open or otherwise, are later additions and are probably illegal if concealed and should be covered if not concealed (all as of the time they were installed.)
I am not sure what all of the options were for lighting fixture connections, or what type of bushing or connector is needed when entering a box with K&T wire.
Those light bulb sockets appear to be "temporary" using sockets designed for festoon lighting or construction of luminaires and need to be supported. Also the junctions have to be in boxes.
Whether the inspector requires all of these to be corrected before signing off is probably a local variation. My guess is most or all will have to be remediated, since the integrity of the original K&T has been disturbed. It may be easiest to abandon the whole thing and pull new home runs.
I don't know that this is true. K&T had its own section in the code and it says that soldered splices are allowed. It makes no mention of j-boxes.... a junction box is required now....
It looks like 300.15 allows for splices in K&T to not have a box. The only place 300.15 requires a box is at an outlet or a switch point. That, to me, makes the surface mount cleat socket in my earlier post non-compliant. But splices without a box seems to be OK if soldered or using approved splicing devices.
You are not alone in so doing. And there is nothing wrong with doing more than the minimum that the NEC requires.They way I have practiced and interpret 300.15 is that you need a junction box or raceway with an accessible/ removable cover when splicing conductors.
The NEC requirements for Knob and Tube still allow splicing as seen in original K & T. These K & T code requirements are the exception to the generalization that "all splices go in a box".
I don't quite understand where I am wrong, but I'm sure someone will show me.
This is why I enjoy these forums, I get to see code interpretations other than my own.
I just don't see in the code where it is written for (lack of a better definition) an open air splice like in a basement or attic is allowed. 300.15 , require a box and (A) no box if wiring methods with removable covers, such as wireways, multioutlet assemblies, auxiliary gutters and surface raceways. The covers shall be accessible after installation. (I look at this as some sort of junction box).:huh:
(F) Is referring to the use of an approved change over fitting instead of a box right?![]()
No. The "change over fitting" is described in 300.16(A).(F) Is referring to the use of an approved change over fitting instead of a box right?![]()
What can legally, today, be open air spliced to existing K + T ?
2011 NEC Chapter 3
300.16 Raceway or Cable to Open or Concealed Wiring.
(A) Box, Conduit Body, or Fitting. A box, conduit body, or terminal fitting having a separately bushed hole for each conductor shall be used wherever a change is made from conduit, electrical metallic tubing, electrical nonmetallic tubing, nonmetallic-sheathed cable, Type AC cable, Type MC cable, or mineral-insulated, metal-sheathed cable and surface raceway wiring to open wiring or to concealed knob-and-tube wiring. A fitting used for this purpose shall contain no taps or splices and shall not be used at luminaire outlets. A conduit body used for this purpose shall contain no taps or splices, unless it complies with 314.16(C)(2).
Life tosses all of us some funny bouncing balls. It sure sounds to me like your customer was lucky to find someone who was honest and did what was right.
