KO punch
Re: KO punch
We always use Greenlee. They seem to last forever if they're not overly abused. They are expensive however. Here is a link for more info:
http://www.toolup.com/productinfo.asp?id=7310SB&Manuf=Greenlee
Re: KO punch
Greenlee seems to be the only game in town for hole punches. Except Harbor Freight has a small set for like $20.
But if you just need holes in sheet metal, I suggest you look at this site:
http://www.hougen.com/cutters/sheetmetal/Holcutters.html
They look like little hole saws but are much better, faster. But these only seem to go up to 3". And a lot cheaper than a full blown Greenlee hydraulics set [which is also heavy].
Perhaps if you really need the 4" capacity, you could get just the pump, stud and 4" punch and die. What excuse do you have for 3 1/2"? That size seems to be another candidate for obselesence and extermination [along with the doomed 1 1/4"].
~Peter
Re: KO punch
~Peter
I actually use 3.5" PVC. I often have to run 2 to 3 sets of 500 (single-phase) from a panel to an underground transformer, and for the cost difference between 3" and 3.5", I really like the extra room.
Re: KO punch
Well, as long as it's PVC, I guess that's OK. My head is always focused on EMT and THAT [3.5"] IS an oddball size. I was thinking of the logistical problems of keeping all the 3 1/2" fittings and clamps and supports on hand but underground you don't need all that ancilliary stuff.
~Peter
Re: KO punch
There is also another company called Ensley, or at least there was another company called Ensley that made good ko punch kits. They were cheaper than Greenlee. I have not seen any Ensley tools sold at wholesale houses for a number of years now. Greenlee is a good way to go.
Re: KO punch
Peter the job I will be starting soon has 3.5" EMT specified for some runs.
Not an issue, we do not 'stock' much above 1".
I make a list and order what I need when I need it. :)
By the way, 1.25" is not a going anywhere either, it is commonly used for 100 amp feeders and services.
As it is the largest hand bender size it has some advantages, although I will buy the 90s.
Re: KO punch
Along with Greenlee I have used Enerpac punches.
Either one gets the job done.
If you go with a Greenlee 1/2" to 4" set make sure you go with the metal case and treat the latches on the case carefully they always seem to break.
Once in a while you will get a leak, usually in the valve on the pump. It is just an O-Ring that can be purchased at any hardware store and replaced in less than a minute.
The company I work for beats the heck out of any tools and these Greenlee punches put up with a lot. If you treat it well I bet you will have zero problems.
Re: KO punch
It takes a big person to use a bender with an auxillary foot peddle. :)
Re: KO punch
Originally posted by jbwhite:
It takes a big person to use a bender with an auxillary foot peddle. :D
I agree, I have the model with the foot pedal and I am more than 200 lbs. :p
As I said I will still buy the 90s but making offsets and kicks is fairly easy.
Re: KO punch
Augh, you guys are just sissies.
At 6'2" and 235lbs. I don't have to much trouble even with 90's. You just need a little lead in your britches. :D
Re: KO punch
EDIT: Image deleted by Ryan
[ January 15, 2006, 02:36 PM: Message edited by: ryan_618 ]
Re: KO punch
Jim, I think Greenlee has a group of people who deliberately handles the new pumps until they look worn like the one in the picture before they allow them to be sold. :roll:
Roger
Re: KO punch
Originally posted by jimwalker:
Is it new or used ?
Did you look at the pictures. :D
It's well used, it needs a new draw stud, the first 1/2" of threads are ripped off which likely means one of the cutters has thread damage as well. :p
