Hello,
As an electrician I have always been taught that voltage drop was compensated for by increasing conductor size, shortening the length of the circuit or using a smaller load. But the other day our staking engineers quoted a customer a 25kva transfomer vs a 15kva unit to compensate for the voltage drop.
Have any of you used this methed? They have a piece of software that you can change kva, wire size or circuit length to get desired voltage drop. I am curious to hear peoples thoughts on this. Personally I can't get past the idea of the wire being the bottle neck due to resistance.
As a side note the bigger transformer was only $100 more than the smaller one. Bigger wire would have been a couple hundred more so they saved the customer money if their assumption/software is correct.
Thanks for your thoughts and comments,
RLCGuy
RLCGuy
