- Lockport, IL
- Semi-Retired Electrical Engineer
Did you read the meter yourself, and if so is your reading consistent with the utility's reading?Consumption is very detailed and consistant over last 3 months.
If it is a light, it could be 300 watts of lights that have a bad photo cell (normally a 50% duty cycle is now 100% duty cycle). Got some security lights on a photo cell?You are looking for 130 to 150 watts of continuous use.
Yes, I do. I haven't noticed any abnormal light, but will check.If it is a light, it could be 300 watts of lights that have a bad photo cell (normally a 50% duty cycle is now 100% duty cycle). Got some security lights on a photo cell?
What does your reading show as the average kWh per day since the last utility read?I started recording readings today.
BTW, your usage roughly doubled, not tripled.typically 30-35 days
high reading 42 days
My utility bill doubled last month, and my usage tripled.
Anothertypically 30-35 days
Did you only consume 264 KWH in 42 days. or 6.3 KWH/day, and even less 95 KWH in maybe 35 days or 2.7 KWH/day. 2.7 KWH/day is a mere 0.123 KW continuous load.norm 95 KwH
high 264 KwH
Good point. I forgot about the attic & crawl space lighting. Same would go for any non-frequented space like a storage building.Check your attic lights! I had a customer a while ago with a spike in the bill and it turned out to be 6 100 watt lamps burning in the attic for over a month!
Is there a strange RV parked nearby?
