MIEngineer
- Michigan
All,
I have an estimated load from a facility that has yet to be built. I have been asked for the estimated carbon output. To do this I will base it from the building energy use. This is where the problem lies, I am having issues thinking how to calculate the building energy use from the load calculation.
Is one approach to simply assign run times to all the loads (i.e. lighting 32.6 kVA*10 hrs = 326.5 kWh/day, assuming pf=1.0). Also any insight as to the contribution of occupancy sensors for lighting and VFDs for motors would be helpful.
If it helps put in perspective this is a high-level estimation meant to be on the conservative side. This is a mixed-use building with repair garage, office, and storeroom areas (approx. 21,000 sq. ft.).
Attached is load information from the design engineers.
thanks in advance for any assistance,
Todd
Todd
