peter d
- New England
boboelectric said:do you just buy your material there?
iwire said:Lowe's purchases the wire and ships it to us.
growler said:And why not? With the sure volume of wire purchased by either Lowe's or Home Depot they can probably get and even better deal than most electrical suppliers. :grin:
It would be interesting to see what a spool of #12 THHN solid cost straight from the manufacturer when you can buy about a billion spools a year.
iwire said:They told me to.![]()
The entire job is pipe other then re-loc for the lighting fixtures.
It appears to be a Lowe's choice, security in pipe as well.
LawnGuyLandSparky said:The Milwakee sawzall purchased at HD is NOT the same one you'd get from a tool supplier, even though the "model numbers" are identical.
iwire said:Edit; To be accurate the Japanese company that owns AEG, Ryobi, Stiletto, Homelite, Hoover, Dirt Devil, and Vax also bought out Milwaukee.
I use labor and material in a wall opening dollar value per unit. 100 to 200 feet of small conduit would be a good estimate on 8 hours. obiously larger jobs have room for a lower value per opening. I figure on 100.00 per opening on nm cable jobs with an addition for special circuits or service gear. On commercial I figure on 150 to 200 per opening plus fixtures and load centers. On larger jobs of the emt 2 hours per opening with materials at 25 to 30 % comes up to 250 per opening and add the fixture lot package quote from supplier and switch gear and any special equipment added.SmithBuilt said:How long does it take to run say 100' of 3/4" emt in hours? No wire just boxes and emt.
Does anyone use a sliding scale. ex. If you had a small job of 50' to run . The time in labor would be more than 100' run.
Or if the run is much longer less time involved. I'm using 8 hours per 100' for estimates now, but I'm starting to think that is too much time on a large job.
