- Massachusetts
Re: Lamp life too short!
If your saying the connection is so bad that the filament is actually cooling down significantly this would be noticeable to the eye and would suggest a loose connection.
Would this not be a problem when opening the light switch too?
There would be a lot of dark buildings if wire nuts failed as much as that.
Just my opinion formed from installing tens of thousands of wire nuts.
Bob
Understood but seeing as this is an AC circuit you have the voltage going to zero all the time anyway.Originally posted by oldmanriver:
2. Iwire - The reason arching causes the shortening of the lamp life is two fold, first the current rush into the filament is the primary thing that causes bulb burn-out,
I would like to see some figures that show the inductance in a typical lighting ciruits will cause peaks of 240 volts to the filament remembering the peak to peak voltage is already about 180 volts.Originally posted by oldmanriver:
then you will understand why the voltage in an arching circuit will easily jump to over 240 volts and blow the lamp.
I suggest you do not do that unless you can find some wire nuts that say solder first. ) Wire nuts when used as instructed do not fail nearly as frequently as you make it sound.Originally posted by oldmanriver:
I suggest going back taking off the wire nuts, twisting the wires, well, soldering them, then re-install the wire nut.
Bob
