1. Bring the mason some doughnuts/coffee.
2. Before the column footings are poured, trench and install conduit stubbing up appx 42" above grade in the center of the block/brick columns.
3. When the columns are started but not complete (in order to get an ACCURATE measurement), install your jboxes, face up, landing flush with the finished top. (measure up from whatever coarse they are at). Be sure and duct tape your boxes well. Masons love to dump mortar into our conduits.
4.The masons will install the cap layer around your jbox and you can mount your fixtures to the JB or to the column cap.
I generally like to pull wire before everything is backfilled/complete (the just in case factor) but, if there are no hidden issues, it will be easier to pull wire after the columns are set. If you DO pre pull wire, install blank covers on the jb's to keep the wies out of the masons way and to keep mortar out of the components.
If the fixture have a big base with lots of make up room, you could just stub the conduits up, cut them off flush and use the fixture base for wiring/make up. Does code require a jb in this case? I don't know.
