chevyx92
- VA BCH, VA
Why do manufacturers rate the fixture for a max size bulb thats way under the rating of the socket. I've seen numerous fixtures rated MAX 65 WATT yet the lampholder is rated 660 watt. Why is that?
Happens to me all the time. I either type too slowly or I just don't know when to stop talking. :grin:Dennis Alwon said:You beat me too it charlie
lowryder88h said:Also after many years of over wattage the KT, AC, or NM conductors become brittle and fall apart and may become an area of the often said cause (electrical fire)
chevyx92 said:I don't buy that one bit. You mean to say that a 100 watt bulb vs a 65 watt bulb in a fixture supplied with 12/2 NM will become brittle when your not even talking about an amp!??!!
Dennis Alwon said:I'll buy some of it. If it is the old nm etc 60 degree wire it will get brittle over time. I have seen it, but I doubt it would cause fires-- short out--yes, hurt someone--yes. By the way what does it cost to buy part of it?
chevyx92 said:If the wire is rated for anything it can handle an amp!!! 65 watt or 100, it's not an amp. I don't know of any wire that can't handle that. Do you?
Dennis Alwon said:I believe it is a matter of trapping the heat inside. Thing of it this way, a 100 watt bulb is almost twice the size of a 60 watt bulb. If you put that in a small enclosed fixture the heat will be significant.
chevyx92 said:But you still miss the point. If a lampholder is rated 660 watt and fixture max is 65 watt, your telling me that if I put in a 100 watt bulb the wires will become brittle and cause a fire? I don't tend to believe that. Because on the other hand if you have a lampholder rated 660 watt in a fixture with a max of 100 watt bulb it's no difference. Considering they are fed from same size circuit and wire.
So tell me about jelly jar fixtures then. They have very little room in them.Dennis Alwon said:A fixture that is rated 100 watt will have a larger enclosure in order to allow the heat to dissipate. Check out a fixture rated for 60 watt and one that is rated 100 watt. The lens or glass is larger. I am talking about enclosed fixtures not recessed cans where the bulb can breath.
chevyx92 said:So tell me about jelly jar fixtures then. They have very little room in them.
Dennis Alwon said:And what are they rated--- I have only seen 60 watt on them . I am sure they make larger ones. Also they are not ceiling mounted fixtures. Heat rises-- jelly jars are 90 degreee to the wires. Have I convinced you yet.
chevyx92 said:I've seen some rated 100 watt max as well as 60. And who said jelly jars are 90 degree to the wires????? You've never seen a jelly jar on the ceiling???
Dennis Alwon said:I realized when i wrote that that I was wrong. I stand corrected on the dam jelly jars but I am certain on the heat buildup and wire damage. Why one fixture is rated higher or lower I am not sure. But the op was why the socket was rated 660 and that was nicely answered by post #2 Charlie. I was just trying to explain what I know through my own experience-- you don't have to buy it if you don't want. If you put a bulb to large for the fixture I will guarantee you that it won't burn very long-- a week or so-- why is that ?? Heat,that's why.
Because the socket itself is a component, whereas the luminaire is an assembly. The rating of the assembly must be observed in installation and use.chevyx92 said:Why do manufacturers rate the fixture for a max size bulb thats way under the rating of the socket. I've seen numerous fixtures rated MAX 65 WATT yet the lampholder is rated 660 watt. Why is that?
chevyx92 said:Well we have 2 different expierences with this. All I'm saying is if the wire is rated and lampholder is rated well over it's capacity then I see no harm in a few extra watts! I'm not saying that this is a common practice just theoretically. You mean to tell me you have never swapped out a 65 watt for 100 watt bulb before??
LarryFine said:Because the socket itself is a component, whereas the luminaire is an assembly. The rating of the assembly must be observed in installation and use.
How about an experiment of your own: install a recessed light somewhere in your home and install a 150w bulb in it, and let us know what your findings are.
Hint: if the bulb cycles due to the over-heat limit-switch in the luminaire, consider yourself fortunate that you didn't need to break out a fire extinguisher.
Because a luminaire is made up of more than just the socket and the wire. There's also the enclosure, the trim or lens, the installation itself, surrounding insulation, etc., all of which contribute to heat build-up and dissipation.chevyx92 said:What's the harm in installing a 100 watt in the 65 watt fixture? The wire and socket are rated for it.
