IntegrityOutdoorLighting
Hi Guys im new here and look forward to learning more as well as helping when I can.
1st off a 500' loop is a no no. You gotta break that up into multiple runs. Your load on your secondary breakers would be way to high as most pro line and contractor transformers have a limit of 25a on the output commons.
720 w for me would probably be at least 5 runs. You can probably actually save wire by not doing the loop, get more even lamp output as well as be more effeciant and not to mention extend lamp life.
Optimum voltage at the fixture would be 10.6 to 11.5 and its important to check it at the fixture under load.
Another good method of wiring no one mentioned is the Hub method. Run your 10ga or 12ga lead from the transformer to a "hub" then group 4-6 fixtures together and bring em to the hub and make 1 splice. Some high end low voltage fixtures come with or are avalible with 25" of 16ga lead wire.
THe T method is also handy where you bring your main from the trans in around the middle of the run and place 3 lamps on each side of your main line (3 lamps is a generic number its gonna vary depending on lenght and wattages)
Dont daisy chain unless its just a few lights or a short loop.
Hope this helps some
Billy
www.integrityoutdoorlighting.com
Billy
