This is actually a continuation of an old post I came across. I thought I had the voltage drop calculations down to a science until I read it. To simplify and make things easy I'll give exact numbers to eliminate confusion even though i'm the one who is confused here. Please with all due respect, serious inquiries only as to answer my questions correctly, you must take the time to look at what i am doing here if you will. Thank you.
EXAMPLE 1) Ok, so If you have one 60w lamp at the end of a 1000' run, I would do it like this:
2X12.9X.5aX1000'/3.6v = 3583cm(#14awg will be sufficient)
EXAMPLE 2) This is where i got confused. If four 60w lamps total were in that 1000' run, each 250' apart(the first lamp 250' from power source), i would do it like this:
To find wire size from power source to first light i would do this:
2X12.9X2aX1000'/3.6=14333cm(#8awg will be sufficient from power source to first light)
To find wire size from 1st light to 2nd light i would do this:
2X12.9X1.5aX750'/3.6v=8062cm(#10awg will be sufficient from 1st to 2nd light)
To find wire size from 2nd light to 3rd light i would do this:
2X12.9X1aX500'/3.6v=3583cm(#14awg will be sufficient from 2nd light to 3rd light)
To find wire size from 3rd light to 4th light i would do this:
2X12.9X.5aX250'/3.6v=895cm(#14awg will be sufficient from 3rd light to 4th light.
Questions:
1) Are my calculations correct?
2) Assuming my calculations are correct, if i do the reciprical of EXAMPLE 2 assuming an exact 120v power source, "WHY" do i exceed the 3% permissable voltage drop by using these size wires?
Power source to 1st light wire size check:
2X12.9X2aX250'/16510cm(#8awg)=.78134464vd.....Therefore 120v(at power source) - .7813446vd=119.2186554v(at 1st light)
1st light to 2nd light wire size check:
2X12.9X1.5aX250'/10380cm(#10awg)=.932080925vd...Therefore 119.2186554v(at first light) - .932080925vd = 118.2865745v(at 2nd light)
2nd light to 3rd light wire size check:
2X12.9X1aX250'/4110cm(#14awg)=1.569343066vd...Therefore 118.2865745v(at 2nd light) - 1.569343066vd = 116.7172314v(at 3rd light).
3rd light to 4th light wire size check:
2X12.9X.5aX250'/4110cm(#14awg again)=.784671533vd...Therfore 116.7172314v(at 3rd light) - .784671553vd = 115.9325598v(at 4th light) WHICH EXCEEDS the 3% voltage drop permitted which would be 116.4v?
What did I do wrong?
Questions:
