Re: Large equipment Egress
I really don?t understand what you are trying to describe. But here?s a few tidbits that may help:
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">If you are working on the equipment, and you want to leave, and you head toward the exit, and you find that you have to open a door in order to get out, then that is OK. But the door has to open outwards, and has to have the ?panic hardware.?</font>
<font size="2" face="Verdana, Helvetica, sans-serif"></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">If you can stand anywhere along the front line of the switchgear, and you can see a clear path between yourself and the exit door (meaning that there is no structural column, conduit run, or electrical box you would have to walk around), then 110.26(C)(2)(a) might apply.</font>
<font size="2" face="Verdana, Helvetica, sans-serif">I said ?might apply,? because there are two additional considerations:
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">If you have to be able to work on the back of the switchboard, and if you would therefore have to walk around to the front before you can see the exit, then you must have a second exit installed.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">In order to work on any given section of the switchboard, you have to open the front panel cover. Suppose that the panel covers are hinged (i.e., you do not get to take them off completely). In order to take credit for the ?unobstructed exit,? the panel covers have to swing in a direction that would not place them between the worker and the door. In other words, while you have your hands inside the switchboard, turn your head toward the exit. If you see the hinged open panel cover, then the path to the exit is not ?unobstructed.? I would strongly suspect that your installation would fail this test. This is similar to what I think Steve had suggested.</font>
<font size="2" face="Verdana, Helvetica, sans-serif">Does this answer your question?
[ December 16, 2004, 10:32 AM: Message edited by: charlie b ]
