Lcdrwalker
- Columbus, Ohio
Utility 'area'.
Lcdrwalker said:Utility 'area'.
scottysolar said:doesnt a 30 amp dedicated outlet satisfy the requirement
Chamuit said:I would say no. What you are describing is a nook or closet not a room. It might come down to whose definition of room you have to use.
Chamuit said::grin: If you have a closet and you put in a 30a 240v 4wire receptacle for a combo unit. Shove the unit in front of the recept and there is not any usable space left around the combo unit do you have a "laundry?"
Chamuit said:Be like cutting a hole in the wall, put a frig in and call it a kitchen.:grin:
LarryFine said:Food for thought: Not all stackable machines share a single power cord; many do require the separate 120v circuit.
Dessert: Is a 240v dryer circuit required even when a gas line is installed for a gas dryer? I've been told they are.
stickboy1375 said:I find it strange I am forced to install anything to do with laundry, seems like a luxury item to me...
Never liked 210.52 anyhow.
Same here. Common sense says there needs to be a place to plug the washer in.480sparky said:Why would where the laundry be located make a difference? I've done laundry circuits in laundry rooms, utility rooms, mud rooms, bedrooms, bathrooms, basements, closets, hallways, garages.....
These may all be luxury items but the requirement for the 2 SABC's are for the protection of life and property. They are a good idea!480sparky said:So are coffee pots, mixers, bread makers, cappucino machines, popcorn poppers, malt mixers and mircowaves. You still happily install the two SABCs, don't you?
iaov said:These may all be luxury items but the requirement for the 2 SABC's are for the protection of life and property. They are a good idea!
That only applies to buildings that include more than one dwelling unit. For a single family dwelling unit, you don't get to omit the laundry outlet.iwire said:Your not forced to install it when the builders of the home decide not to include a laundry area. If there are no plumbing or vent hock ups you can forget the outlet.
Lcdrwalker said:Could this be a matter of semantics? What if the laundry equipment were in a utility are instead of a laundry room or maybe a closet?
Why? There is no requirement for a dwelling unit to contain a laundry room.brantmacga said:then you change the name of that space to "laundry room".
