lazy susan
RUWired said:
well ,what i don't see is how you can use 300.3(B)3 to support the use of this wiring method.This article is only referring to single" conductors".The reason for me saying that is that it refers you to 300.20(B)
I do not agree with you that 300.3(B)(3) only applies to single conductors.
LarryFine said:
ramsy said:
Does Larry use plastic boxes, or otherwise snip the barrier between metal knockouts to comply with the provisions of 300.20(B) ?
Let's see.
"Why, yes. Yes, I do."
Hey, Ramsey, he does. :D
This calls for a code revision:
"There is no such thing as a stupid question" is hereby amended with the FPN "Until asked in stupid grammar." 8)
butchetsetera said:
yeah, i got the 3-ways done. when i posted the question, i couldn't wait for an answer. I had to just get it done. for some reason, 3-way swithes wouldn't work. I had to use what they had installed before (4-ways) using only 3 terminals.
this doesn't make sense ... WHY ... please explain why a 3 way won't work and a 4 way will ... something sounds a bit screwed up to me .... m
