I am ready to run power to an outbuilding through a 1 1/4" PVC LB connector outside, to the service panel inside. I'm contemplating running the wire through the LB, directly into the backside of the service panel.
The Problem: Finding a fitting, connecting the conduit through the wall, which will not protrude deeply into the service panel.
Q1: Does the fitting attached to the conduit inside the panel need to be secured with a lock ring?
Q2: Is there a standard/better way to mount an LB connector to the wall either above, below or into the service panel?
Many thanks in advance,
Richard Linespike
Richard Linespike
