Eddy Current
Anybody know of any good online resources to learn about 480V lighting?
Learn what?
Run wires to'em, turn 'em on. The rules are the same as any other lighting.....egc, circuit sizing, overcurrent.
Typically not... at least not with any common-to-USA supply system.I didn't think there was a neutral?
I think the hardest part for some to understand is how to run 480V lighting on a 3Ø circuit.
No there isn't a neutral, there is a complete circuit though, just like a water heater or motor.I didn't think there was a neutral?
The wiring is different: (3) 2-pole, 2-wire circuits vs. (1) 3-pole, 3-wire circuit... although there is nothing to prevent this from becoming (3) 2-wire circuits.Circuit 1 phases AB, circuit 2 phases BC, circuit 3 phases CA. Use two pole breakers, if you want, for each circuit or a three pole if you are happy with one breaker. Nice if the loads are balanced.
