Depends on the code book one is trying to learn!.......The NEC"What's the best way to learn how to use the code book?"
Every person learns differently. That said, the best way I have found, if you are referring to the NEC is this. Read entirely chapters 1-4. All electricians need information from all of these chapters every time they pick up a tool. Then using any of a ton of resources, find practice tests, test questions, code questions etc. Mike Holt has some great books for this along with on line resources from him and others. The thing is that the questions themselves aren't really that important. Whenever you are wanting to study, read the question, use the front table of contents and try to surmise which chapter and section the question is in. Find the answer. This is important, just because you know the answer still try to FIND it. You will,over time, start to know what type information is in what section. You will find amazing little snippets about other things every time you open the code, and then think, "Oh no, I violated that one before!" One other thing. Any time you are told, "The code says..." Look it up. You may or may not ask the person to tell you where it is, this can be "insulting" depending on the situation, but don't take any of us at our word. Read EXACTLY what the code does say. Personally I don't think you need to do much else to learn the code, with the possible exception of getting someone to tutor you on doing load calculations.What's the best way to learn how to use the code book?
If you can find good classes in your area I would highly recommend them. In a class setting you not only get the perspective of the instructor but the experience and perspective of the other students which may bring up issues you never even thought of.
This forum helped me learn the NEC. Starting very early on (and I have been involved in this forum for over 10 years), I would read other members' opinions on code-related issues. Then I would look up the articles that were cited by the other members. It helped my find my way around the book.
The best way I've found is to get involved in real world situations with experienced folks where making something code compliant is necessary. Practical applications tend to stick with you better than hypothetical ones.What's the best way to learn how to use the code book?
But getting enough diversity of experience that way to pass a test can take a long time and may require changing jobs a lot.The best way I've found is to get involved in real world situations with experienced folks where making something code compliant is necessary. Practical applications tend to stick with you better than hypothetical ones.
FWIW, the OP didn't say anything about a test.But getting enough diversity of experience that way to pass a test can take a long time and may require changing jobs a lot.
For the general goal of learning how to use the code book, yes, specific examples will teach you procedures that apply throughout the code. Such as always look for a different section that changes what you thought you just figured out. And that the wording is usually finely crafted for a reason and don't be too quick to apply common conversational English processing to the Code.
And that on rare occasions, it just seems to be screwed up.
Using a searchable electronic form of the NEC can be a big time saver over just working from a dog-eared hard copy. At least when going into an unfamiliar part of the Code.
Nope, but I did.FWIW, the OP didn't say anything about a test.
